what stb's are you single plane guys using?
Curious. Haven't seen too many pics of engine compartments with a strut tower brace and a single plane. I'm looking to go with a vic E and an intake elbow from intakeelbows.com. Just trying to get an idea of what will clear. I have a 3 point edelbrock brace right now.
Let's see some pics!
Re: what stb's are you single plane guys using?
Since most cases require cutting the cowl, you aren't going to see many STB's on cars with single planes. The only spot it could even have a chance of fitting would be well under the cowl, almost to the firewall and I don't believe there is one out there like that.
LG Motorsports used to make a "3-point" that had only one bar bent in deep "V" that connected to the bottom of the cowl, and no cross-bar directly connecting the shock towers.
stockssn2o
05-25-2015 08:54 AM
bossco
11-29-2014 10:18 AM
