What switch won't let the car start when in gear? (A4)
I assume there is a switch somewhere that cuts power to the starter when the car is in any gear except "P". Is there a way to bypass it? I am going to pick up a 700r4 to put in a 95 z28 right now. Madwolf is taking care of the PCM changes for me. Am I going to have trouble with the switch that kills the starter when you are in gear? Is there any other problems I am going to run across?
Also, does anyone have a picture of how the starter is wired? I wiring diagram or an actual picture of it wired up would help.
Thanks,
Dustin
Thanks,
Dustin
Thanks a ton. You (and your website) have been a huge help. All of those pictures come in handy when you are putting together a car that was in pieces when you got it.
Where on the car can I find the "transmission range switch" in the wiring diagram?
thanks again,
Dustin
thanks again,
Dustin
Where exactly is it? To the right, left or above the clutch petal (when looking down at the clutch from the drivers seat)? Can someone get me a picture of it while it is still in the car. Also what kind of connection type is it and what does it look like (pics would be nice)? The reason I’m asking is that my car won’t start when I push in the clutch. But if I bypass the safety switch and run a lead from the battery to the starter, the car will start if the key is in the on position.
I did it by running a lead directally from the starter to the battery.
This bypasses all safety switches . Now I don't want to have to do this every time I start the car. BTW it's parked for the winter so I'm not driving it around and having to start it this way.
I guess I misinterpreted your bypass statement. You are bypassing a lot of things when you jump a cable to the starter.
The clutch switch is on the clutch pedal bracket. Shouldn't be hard to figure out. If you want to bypass the switch, unplug it and jumper across the harness connector.
I don't want to bypass any of my safety switches. I just want to find out what is wrong with my car. It won’t start when I turn the key, so I have to sorta hotwire it. I think that my clutch safety switch is gone, so that’s why I want to know were it is, and what it looks like.
