what temp your guys's lt1's run at?
i had post on here about my car spitting and bogging down when it gets hot, usually 210 or above. but it gets to 210 really quick, like 20 min. or so of driving. is this usual for lt1's or something to look into?
210 is not hot, and 20 min of driving to get there is, if anything, slow.
Whever mine gets up around 210 which is basically when the needle is perfectly vertical I get a little scared and flip on my fan switch. Only because I am afraid of blowing a head gasket. The only time mine gets up to around 210 is if I have been romping on it then got stuck in traffic or if I keep driving around in 1st like in a parking lot for a while.
Hey 94pheonix, Your temp and warm up time is normal. Stock t-stat is 180* Stock fan settings are: fan 1 starts up at 224 and fan 2 at 235. Running open road the air dam usually keeps temp at 180-190*. In stopped traffic you may see 224-235*. Also running the A/C keeps fan 1 running all the time so expect 180-200* with the A/C on. A lower 160* t-stat will only help on the open road thru the air dam , or reprogram fan on/off temps or install a manual fan switch..
