What to use on bolts?
I am in the middle of doing the LT4 Hotcam kit, vented opti swap, heads ported by Lloyd, CSI pump and Cloyes double roller. I know it's a general rule to use only antiseize on bolts going into aluminum but is that true w/ ALL bolts going into aluminum? In other words, what if anything should I use Loctite on during assembly?
I know this may be a stupid question to some but I just want to make sure I am doing it right the FIRST time.
TIA
TIA
doh, forgot about the waterpump bolts. might want some loctite on the cam retainer plate as well.
also on the rocker arm studs
just pick up some arp thread sealant
personally i wouldn't reuse old stock stuff in something so important.
carguyshu
01-22-2017 11:19 AM
