What to use to remove crank hub??
A traditional "harmonic balancer puller" will work. However, most have a large shaft and you will have to put something inside the crank threads to protrude out, so the puller shaft will not push against the hub. You have to do this because the hole in the hub is small. Whatever you use, don't let it get stuck the crank thread hole.
10-31-2016 11:09 AM
cyteone
02-07-2015 06:04 PM
1LEThumper
07-14-2003 12:45 PM
