What valve springs?
What valve springs?
A buddy and me will be putting in a CC305 or equivelant sized camshaft into a 94 Z. What valve springs would you recommend to compliment this cam? Also, would Ti retainers be worth the cost or just get a set of regular chrome moly be fine?
Thanks,
Thanks,
I'm really not wild about places dumbing down part selection by just saying theyre "good to .550"... b/c who knows what they mean by that. Do they bind at that? I'd assume not, but how much bind clearance is there at .550" since thats what they claim theyre good for?
That cam's going to theoretically lift .544".. I'd want something with .060"+ coil bind clearance.
I'd probably run the cc987's with a 4770 locator & a +.050" lock & shim it to get a 1.80" installed height.
Originally posted by slp223
crane 10308 come with everyting you need and with handle a bigger cam then a 305. this way you dont have to peice anything together.
I don't remember the CC p/n, but some claim the L98 oem spring locators will fit, but the oem LT1 locators and retainers will not fit those larger springs.
