What valves should I install????
I just bought a set of lt1 heads with a 3 angle valve grind that included stock valves.
I just ported and polished the heads and was wondering what type of valves I should install. I was told that the stock valves are a bad design. I'm going to be running a hotcam with 1.6rr's.
Any feedback would be greatly appreciated
Thanx
Thanx
rev valves from www.comotorsports.com
Originally posted by Anti-Blinging
...i thought the valves were supposed to be done with the valve job... how else would they seat right?
Dude i hope you dont plan on putting it together yourself. What the guy on top was trying to say is the stock valves where ground to match the seats for a perfect seal. If you buy new valves the valves would have to be reground to match the surface angle of the seat. SO the 3 angle valve job you just did was a waste and has to be done all over again.
Thanx
10-31-2016 11:09 AM
GA93FORMULA
07-24-2002 11:38 PM
