What will i run
What will i run
I just got some hooker long tubes, 52mm throttle body, slp cold air intake, slp loudmouth exhaust, lt4 hot cam kit with everything, some nitto 450, custom pcm, and 160 thermostat. What should i exspect to run?
What's up Wes? Your car would run a very low 13 or maybe high 12's but gears would really help you capitalize on it's full potential. I'd also consider a torque converter. Shop in Galveston does a lot of TransKing for the stroker cars, or a Vigilante would be good too. Are you doing roller rockers with your hotcam setup?
hey brett I'm doing good. i just got some 3.42's i forgot to tell you about so add that into the time. Yea the kit for the lt4 hot cam is rockers, cam, timing chain, all that ****.
10-31-2016 11:09 AM
