What would cause a cam to walk?
Re: What would cause a cam to walk?
If the cam plate is missing or worn it'll walk all over the place. i recommended it as one of the things to look for. The plate is located behind the upper sprocket on your timing chain. If the cam walks forward and back it not only ruins the cam, but will take the distributor, or in the LT1's case, the oil pump drive and chew the teeth off of it. Just something to look for. My gut feeling says it may not have happened, but I like to be over cautious...but that's me.
chris
chris
Noct
05-26-2016 10:26 AM
mark0006
02-03-2015 05:12 PM
