Whats the cheapest way for me to run 13.0?
Originally posted by WrecklessZ
With out NOS or supercharger what the cheapest way?
If you're close to sealevel, you'll need mac headers:$400, cutout:$75, ET streets: $350, and maybe gears:$600+. You didn't say if you had an auto or 6-speed. I'd guess auto, so you could pick up a stall convertor for $300. If you're a good enough mechanic, you can pick up almost 50 hp with a cam change. Cam would be ~$300. If you install stuff yourself, I'd guess $2500 to $3000 would get you there.
Originally posted by PoorMan
cheapest? NX wet kit
If you are any good with suspension work, fool with that some. That would get you there a little cheaper with minor mods. Course then you have the chance of breaking the 10bolt.
If you can build motors, I built a 383 with no topend work for probably around 2000 bucks. Probably more close to 2500 but still on the cheap side if you know how to do all the work. That should have a low 13 or high 12 in it if we could get the car to stick.
Well with bolt ons you must have two things before you even think about 13.0s- Traction and good weather.
First off get some headers, MACs, SLPs, or long tubes. Off road pipe with cutout. If it's an auto get a stall converter, I got one used for $50. If it's a six speed learn to drive like a maniac and get some 4.10 gears.
Get a tune via LT1_edit or tunercat, squeeze everybit of HP out of your motor.
Get every bolt on you can possibly get, electric waterpump, 1.6 roller rockers, airfoil(hehe), just whatever you can find.
John
John
