whats difference le1 HL and le1 1.5?
#16
that is exactly what is done.
customers get their cam and read the LE1.2, 1.3, 1.5, etc on the back and post that up. It doesn't mean anything really other than their specs were a lil different than the most common LE1 cam used.
Lloyd
Lloyd
#17
He doesn't market them like that. He markets an LE1, 2, 3 and people want it tailored more to there setup so they make variations. Like Lloyd said it helps when buying a used cam because if they didn't mark them differently then when you buy a used LE1 cam there's no telling what you're getting because they are all not the same. I don't see a problem with it, it's not rocket science.
#18
It's not a problem, and agree it isn't rocket science, but it is just marketing however you want to look at it. You see threads all the time asking "should I get the LE1, LE2 or LE3?" with responses that are similar to "I got the LE3.2 cam/LE4 head package" So what? It has no relevance to anything anyway - it's a marketing game. If it makes you feel good after spending your hard-earned money, then more power to you (no pun intended).
#19
Wow, this tread became interesting. Bottom line, I'll be going with the LE2 heads with the beehive springs and just be going to talk to Lloyd with the the things I would like with my cam and such.
Thanks everyone for your input!
Mike
Mike
#20
#21
Hello.
I have LE2 heads and LE1.5 cam. After i made this install , i noticed a lack in the lower band of my torque without the power expected. I beleive the problem come from somewhere else but haven't found where yet (the car is also turning way rich at low RPM).
On the upper side of my curve , i have something normal with 395 RWHP.
Anyone with same set up can send me his power curve so i can see what i should expect instead of mine ? (thinkin wrd1972)
#22
Hello.
Now my stock cam was falling off at 5700 RPM, but the LE1.5 is still pulling hard at 6300 RPM. I have yet to rev my motor high enough to actually feel this cam fall off.
#24
If you want LE cam information from the "horse's mouth", listen/talk with Lloyd (NightTrain66). Much of the information posted by other folks on these cams emanates from the other end of the horse.
Jon
Jon
#25
I have no problems comprehending how the package ratings work. To understand the decimal system is basic math. There is a standard for LE1, LE2,LE3. Any changes to those get a . and a #.
If somebody cant understand that, its time to put down the wrench.
#26
you missed the point. time to put down your wrench.
#27
oh, thank god the literary giant made an appearance. we can all rest now.
#28
Every time I see you post, if it's not an AI product it's not real world results. How about you not criticize on pure speculation. I know everyone is entitled to an opinion but you are doing nothing good for anyone besides making the person who asks a question more confused than when they opened the thread. If you don't understand the LEX.X way of cams that Lloyd and Brent are using then don't try to confuse everyone else with you. Try being an all around cool guy for a change.
#29
