Whats the highest rpm you can safely run a stock lt-1
#31
I seriously disagree with that....(I assume you are referring to 4 bolt mains).
If that was the case why bother with four bolt mains on any engine(btw LS1 has 6 bolt mains..yeah, guess they are irrelevant...)....plus if the main caps distort under high rpm you are in a world of hurt....bearings will wear out of round I'm guessing....you can then count on spinning a bearing soon.
#32
Dude, we are talking about a 7k maximum Chevy smallblock. The mains aren't even close to being the rpm limiting factor. What you are all worried about rarely happens in our motors. In this discussion, they are completely irrelevant.
#33
Quite honestly the original question falls under the guise of………”If ya got to ask, you probably don’t need to know.” A more appropriate question might be: What is the most effective shift point? These cars can rev quite high as compared to the stock LT1 redline and not blink an eye when it all said n done. Since when was a small block Chevy ever considered anything except a higher rpm screamer??
Where in the world did all this burn out friction stuff come from and what does it have to do with anything??? Hey……….type on dudes.
#34
In a stock or semi-stock vehicle........Nada, zippo, nope. Probably not a tinkers dam even in a pretty heavily modified one unless it's turning a zillion rpm or has a pretty HD power adder. More than likely marketing and perception than anything in a mass produced production vehicle as the Corvette is and always will be, GM's performance benchmark and GM needs to make distinctions whether real or perceived.
Rich
#37
Well i am glad i started this discussion, i think most of us are in agreement, you can rev an LT1 safely above 5800, i think for me i will set the rev limiter at 6100, and shift at 6k, i just know that as long as there is no valve float, you get more horsepowerr that way, hey keep in mind, i am reading the stock tack, maybe i am shifting at 5800, who knows how accurate that thing is.
#39
I'm not disputing the fact that a 2 bolt can be turned higher than the stock rev limiter. As a matter of fact I plan to go around 6200 myself after my cam install.
I just wanted to point out that it is safer to do it with a 4-bolt rather than a 2-bolt. It's a matter of keeping the main caps from distorting. The better you can do that, the less chance of bottom end failure.....and the fact is a 4-bolt will control cap walk better than a 2-bolt.
I will also agree that the valve train is more of a concern than the bottom end on a stock LT1.
I reviewed the buildup of the LS1 that Horsepower tv broke(have it recorded on the computer). They took out a rod bearing and not a main bearing.
#40
#41
That's really quit good and on the other hand.......short shifting can leave a lot on the table. Pro Stock, Pro Stock Bike...leave, shift point, shift point, shift point and shift point. All must be perfect or you loose.
#42
My car with the stock cam was fastest in the 1/8th shifting at 6200 according to datamaster.
#44
#45
But thats just a idea.
