Whats wrong w/ my motor?? (VIDEO CLIP)
Ok i've been having major issues w/ my motor
rockers are all good
oil pressure seems fine!
i dont know
here is a video clip
Video Clip
i dont know
Video Clip
you guys need to listen to it closer... that's VALVETRAIN noise, a rod bearing would be more of a deeper sound, plus he say's that the car runs fine except it just make's the noise.. that's NOT rod bearing symptoms
did you check the pusrods like i told you
The only way it could be a valvetrain noise is if a rocker is one thread away from completely coming loose and its just clattering everywhere...in which case the motor wouldn't run fine anyways since one of the valves either isn't opening at all or barely opening. Well keep us updated I hope its not the bottom end.
Henson071
05-04-2015 12:23 PM
ChrisFrez
03-01-2015 01:33 PM
NewsBot
01-29-2015 07:10 PM
NewsBot
12-28-2014 06:20 PM
