When draining the block..
Re: When draining the block..
Originally Posted by schimek
Nope the sensor is on the left hand side of the block. The knock module is in the ECM.
The knock sensor is in a hole that would otherwise have a plug in it. Pulling one plug out will not drain the other side of the block.
After taking the driver side drain out and putting it back once, I will never do it again. That is the most impossible to reach bolt I have ever dealt with. I finally bent a 12 point box end with a torch and managed to get it in, about 2 deg. at a time once I finally got it started.
