When installing 1.6 roller rockers
I have the:
CC NSA 1.6 rockers
Guide plates
LT4 retainers keepers
LT4 retainers
LT4 springs
What about replacing oils seals and such.
Does anyone have these part numbers?
Anything else I should do while im in there?
CC NSA 1.6 rockers
Guide plates
LT4 retainers
LT4 springs
Re: When installing 1.6 roller rockers
I found the seals part numbers.
Assuming the 95 push rods are hardened,anything else I should purchase for the install?
Originally Posted by BUBBA
I guess some earlier Lts have the hardened push rods, so I will leave that up to those who know.
Originally Posted by wrd1972
Do you guys reccomend replacing seals, the engine has 70K?
93-95 LT1 F-bodies have hardened pushrods from the factory.
Originally Posted by MyShibbyZ28
The seals are cheap. Replace them. Besides, might have some that got old and whatever.
When you say cheap are they cheaper then that?
SDPC has all 16 seals for $47.00.
JEG's has them listed as 11/32" Teflon coated, $22.99...<---that is what I was refering too.
http://www.jegs.com/webapp/wcs/store...1307&langId=-1
#503
Price the seals at your local auto parts store, they are not expensive and you won't have to pay shipping.
You didn't say which guideplates you have. You want the GMPP ones. A search will turn up the part number if you need it.
Probably need rocker studs that are longer for the guideplates otherwise they won't be threaded into the head as far. Be sure not to knick the seals when installing them.
Got the full set of seals from Oreillys for $17.00.
Got the 7/16 CCs studs.
Actually I still need to get the guide plates but they will be the GM plates from SPDC.
I bought a valve compression lever, the one that looks like a small crowbar. I know I cant use this on the rear most valves but my question is how many of the valves will this tool work on. I will get the small screw down kind for the hard to reach ones but we all know what a pain in the wrist it can be.
