When installing water pump..
Just out of curiousity, why put that tape on the threads? I'm assuming the bolt hole has a bottom and doesn't screw into a waterjacket or anything does it? Anyway, I was just wondering because I've never used any to this point.
Originally posted by Hyperspeed97z28
I didnt use anything on my bolts?? just some RTV on the wp gaskets... should I be fine ?
It is a good idea, though, to use a sealant on a bolt that goes into a water passage or is not in a blind hole.
jasonduaine
03-07-2015 09:44 AM
