When is an lt1 not an lt1 anymore
#20
An LT-1 is the 70s engine the LT1 is the 90s one seems to be some confusion above about that.
An aquaintance has a Donovan aluminum block machined for reverse flow cooling, the WP drive, uses a stock opti, and reverse flow cooling heads. Is that an LT1?
#21
I have a oldskool rear mount distributer with a crank trigger for timing and the opti for fuel.
I still consider mine a LT1 since I have an LT1 block
#23
Is it an LT1 if you put AFR/Dart/etc heads on it? Personally I think the aluminum block converted to LT1 front counts.
#24
Actually he made two of those blocks and sold one off. I am just waiting for that thing to pop up somewhere.
I don't know that heads are that big a deal, I mean few of the cars running converted heads are anything that noteworthy anyway. I can think of some turbo cars making amazing power on GM castings one just over 1000rwhp.
I think some of the cars that actually try and go fast using GM parts are the ones far more impressive, using knowledge to go fast over checkbook.
Camaro90RS
07-23-2002 07:57 AM
