Where are 02's and Radio grounded?
Location: Austin, TX or Texas State University at San Marcos
Just got my car back. Brand new 355, but I am having some electrical troubles.... Radio won't turn on sometimes, 02's will mess up. I need to know where these 2 things are grounded because they painted my motor and i think that the grounds are affected by this. Any help appreciated.
Chris
Chris
Re: Where are 02's and Radio grounded?
Doubt they are related. The O2s ground at the coil stud. The radio has a couple of grounds that go to the large posts that are under each of the interior kick panels.
coil stud... Thats where a bunch of them ground together near the coil?? Also my Low oil light is on and the oil level is fine....WTF??
Yes thats where there is a bunch ground at one spot. As for the low oil light, check your low oil sensor on the drivers side of the oil pan. Look and see if it has come unpluged. That would trip your low oil light.
Its pretty much worked out... The car feels bad *** and sounds even badder. Where are you livin' now alex?
Chris
Chris
Bigfatrat
Parts Wanted
10-16-2015 04:48 PM
autoxr166
09-25-2015 04:21 PM
