where can I buy the weather stripping that goes on the rear hatch window ?
Old 08-08-2004 | 10:10 PM
jaytone's Avatar
The former owner must of had the rear hatch window replaced at one time and they never installed the weatherstrip around the entire glass. The weatherstrip I need is the one that atttaches to the glass itself.
Does anyone know of a place to order it ?
Old 08-08-2004 | 10:22 PM
unvc92camarors's Avatar
Re: where can I buy the weather stripping that goes on the rear hatch window ?
the one that goes on the top part of the glass, or between the bottom of the glass and the decklid?
the one i have on top of the glass isn't even on
it just sits below it on the body and i haven't had a problem with it leaking or anything
Old 08-08-2004 | 10:57 PM
Steve0's Avatar
The earlier cars only had the hard plastic weather stripping around the bottom. Later cars came with a peice that went all the way around the hatch.
I thought my car was missing weatherstripping when I first got it too.
Old 08-08-2004 | 11:11 PM
Steve0's Avatar
Heres the thread I made when I was trying to figure otu what was up with my car:
http://web.camaross.com/forums/showthread.php?t=151724
Old 08-08-2004 | 11:21 PM
Heatmaker's Avatar
Advanced Member
The dealer has the trim piece... and trust ne you don't want to know the price... I need one as well... try to shop a junk yard... maybe you'll get lucky.
Old 08-09-2004 | 12:12 AM
$20 is going to break your wallet?
jaytone, the thread link posted should answer the question and I also replied to your post at Project Transam.
Old 08-09-2004 | 08:01 AM
jaytone's Avatar
Yeah, I dont have the weather stripping on the top part of the glass. It is on the left, bottom and right side, but not the top. It looks like it should be there because there is a big (at least looks big to me) gap between the top of the glass and the roof line.
Also, the glue has oozed out somewhat from the weather stripping that is on there and has hardened. I had to take a razor knife to scrape off it off.
So, is everyone saying that there is not suppose to be weather stripping at the top and that I should leave it alone ?
Old 08-09-2004 | 08:13 AM
The new piece is one continuous length that goes around the complete window. No seams, no ooze. It comes with sealant already applied to the piece. A few years ago there were lots of threads about this piece, because of all the glue that would ooze out. The threads have seemed to diminish as the glue has oozed away.
Old 08-09-2004 | 11:58 AM
Heatmaker's Avatar
Advanced Member
$20.00 who's selling them for twenty I'll take it. The going rate around here was $75.00 - $110.00
Old 08-09-2004 | 12:07 PM
$20 is what Dal or Jason sells them for. That's dealer wholesale.
Old 08-09-2004 | 01:27 PM
Originally Posted by 2CNTRY
Is this sealant way in the back of the "inside" of the piece where the window hits or is it supposed to be on both "ridges" that go over and under the window also?
The sealant on the new piece is only on the inside channel where it will only contact the side edge of the window when pressed in place.
Old 08-09-2004 | 02:57 PM
krispy's Avatar
speaking of which, does anyone know if the rear hatch bouncing (squeeking) can be stopped by putting foam along the back edge of the hatch (back by the lock and 2 supports)
01-13-2015 09:52 PM
siguy
11-27-2014 10:07 AM
Bando
10-07-2002 07:36 PM
regular Joe
08-10-2002 07:15 PM
regular Joe
08-08-2002 03:47 PM
Quick Reply: where can I buy the weather stripping that goes on the rear hatch window ?
