Where can I find fittings for a Rad?
When I installed my Be Cool Radiator, it did not come with the fitting for my Oil Cooler Return. I found the fitting at an Autozone on rack full of misc car parts. Figure out what the thread size is on the radiator and the inside diameter of your cooling hose before you go shopping.
Good Luck
Good Luck
Grip I went to Auto zone and they hooked me up with all the fitting do install the radiator. These are the # off the receipt.
721050 61103 radiator drian. $1.99
896167 323318 brass fuel ft two are needed for tranny cooling lines at $1.99
896134 323315 brass fuel ft $3.98
896084 323310 brass fuel ft $0.69
That was what I bought today for my Charged air Radiator Which I still can't get the top radiator support to fit. From the looks of it it will not work. I already grinded a bunch of the plastic away.
How is your install going? James
12-04-2014 11:56 AM
Sarahrope64
11-27-2014 11:17 AM
