where can i get the egr plate block off kit
Or you cold find a piece of aluminum or steel and make one. Take your gasket and trace the outside perimeter and the bolt holes. Then FIRST drill the holes. Place the metal on a block of wood if you have one so you dont distort the metal. Then with a pair of tin snips or even a cutoff wheel trim the block off plate out. Debur it and vua la! You've made yourself a dang neer free block off plate.
Jeremy
Jeremy
stockssn2o
05-25-2015 08:54 AM
