where do ground wires go on coil??
hi guys k, you know you have that "triple ground" that goes on the stud on the coil? k, i put that between the coil bracket and the stud (not between bracket and head), is that the right way? now , theres another "ground" wire, the wire itself is black (not to be confused with the brown one) and it goes on the same stud on the coil bracket as well. only question is, does it go together with the "triple " ground? does it go on by itself, with another nut on the stud? or maybe does it go between the head and bracket? sorry if its a bit confusing, but the answer should be simple thanks a bunch as always
thanks for the reply drop top but what about that other wire that goes there as well? its a single ground (black wire). does it go together with the triple one? or does it mount on top of the stud with another nut? thanks
On the stud nearest the AIR pipe, mine has 2 tan looking wires together on one ring lug, one black wire on a ring lug and one braided ground strap that goes to the chassis. All of them are between the outer nut and the stud.
