Where to get Ported LT1 intake?
97WS6Scharged
I need one because I have a 383 with home ported heads but the intake is missing. I could buy one and port it myself except my electric grinder motor is burned out. So I figured if someone sells them already ported I can get the engine together and in the car faster.
Ported LT1 intakes
I was surfing vendor sites and found two that have ported LT1 intakes for $250 but you get back $100 core charge when you send back your intake. Seth at Combination Motorsports and Racenet Performance.
We do intakes for our motors and heads that are done in the shop, i've seen some "ported" intakes and they are far from it.
The problems I have seen are that the "porting" is just gasket matching and the manifold ports have little done to them, welding is the only good way to get what you are looking for and then after that the guy has to get the port walls straight and parrallel. IMHO i've not seen one done correctly, or up to par with what the intake should be for the money you are going to spend. Jordon's are not cheap but he does them the correct way for the most part.
I've had "ported" intakes in the shop done by shops that have done some big motors that are in/famous on the boards and they were very unimpressive to me.
A LT1 intake is easy since you don't have to strip the powder to weld it up, were a LT4 has to be done that way. I know once I have one welded up and the thing all mocked up with the heads, the porting takes about a day to do.
Bret
Bret
Originally posted by simple
Bret, for comparison sake, what does Bauer Racing charge for their ported LT1 intakes?
Bret
10-31-2016 11:09 AM
oldschool
02-09-2016 09:21 PM
Speeds8erM-1
07-18-2002 11:36 PM
