where to weld cut out?
Check out the 2nd and 5th reply in this thread.
To summarize though, I had it welded on the intermediate pipe right where the other guy's pictures show, but I lost some ground clearance and ended up hitting a raised manhole cap with it, so I had it relocated to the location shown in the 2nd reply.
Don't know about the other thread just mentioned, but I put mine in the intermediate pipe right before it goes over the axle. Where I put it, there is just enough room to angle it sideways (dumping out the passenger side), so I lost no ground clearance; you can't even tell it's there.
"you can't even tell it's there"
except for the awesome sound
i had mine in the same spot before the axle for 2 years without any scrapping.
i suggest maybe buying a turndown so that you can direct the exhaust away from the frame and axle
