Wheres the Cheapest Place to buy LT Pacesetters?
Old 09-08-2008, 07:30 PM
karpetcm's Avatar
Im looking to buy Pacesetter LT's with the Ypipe and i want the LT's to be coated. I want to get them with all the hook ups, were is the place to get a good set ive checked ebay but not sure if thats always the cheapest if you guys can help id appreciate it thanks in advance. Ohh and its for a 94 Z28
karpetcm is offline
Old 09-08-2008, 07:36 PM
LSWHO's Avatar
Shon Herron's site is pretty cheap.
If it's not a sponsor, I apologize: www.Herronperformance.com
Ok I checked he's a sponsor.
LSWHO is offline
Old 09-08-2008, 07:41 PM
karpetcm's Avatar
Just out of curiousity whats the difference if he is a sponsor meaning price wise and how do i go about ordering it from his site do i contact him first saying im a member on camaroz28.com or its just the price thats on his website and thats final. Sorry for the questions just dont know how that works.
karpetcm is offline
Old 09-08-2008, 08:01 PM
2000GTP's Avatar
Generally, the supporting vendors are supporting the website, so in turn, it is good practice to do business with one of them.
2000GTP is offline
Old 09-08-2008, 08:17 PM
karpetcm's Avatar
Forgot to mention i have a tune for longtube headers/no cats and catback system. The tune has not deleted EGR or air wanted to keep those. Do i need O2 extensions still even though the tune is for longtubes no cats. Also the tune is from Madz28, i contacted Herron by email asked him what else would i need other then headers and ypipe. Want to also buy lock bolts and different gaskets then what comes with the pacesetters.
karpetcm is offline
Old 09-08-2008, 08:24 PM
2000GTP's Avatar
Yes, you will still need extensions, a tune is in no way going to help you in that regard. The harness extensions simply extend your existing 02 wiring harness seeing that the 02 sensors are going to be placed further downstream due to the longtube dimensions.
2000GTP is offline
Old 09-08-2008, 08:36 PM
karpetcm's Avatar
Ok good ill order those as well, do you guys think i should use copper header gaskets or just felpro gaskets. Thanks for the advice 2000GTP
karpetcm is offline
Old 09-08-2008, 08:40 PM
bombebomb's Avatar
I got mine from speed engeneering for 375+25$~ shipping.
bombebomb is offline
Old 09-08-2008, 08:41 PM
2000GTP's Avatar
I used the Fel-Pro gaskets, never had an issue with them after a few years now.
2000GTP is offline
Old 09-08-2008, 08:53 PM
karpetcm's Avatar
Speedengineering ill have to go there and check it out just headers with hook ups, ceramic coated is 385 and ypipe is 123.99 and im assuming shipping would be about 25-30 not sure on that part. So ill check out SpeedEng and see what there prices are, gotta also look up headers bolts and gaskets with the O2 extensions.
karpetcm is offline
Old 09-08-2008, 09:02 PM
karpetcm's Avatar
Ok just checked with the Speed and ya they are cheaper and overall it is cheaper for uncoated. I came up with 389.00 uncoated headers and ypipe with the egr and air hook ups. Cost does not include shipping, im looking for coated just for it to last a bit longer i dont know how my 02's will do i heard it damages them as some of the coating comes off.
karpetcm is offline
Old 09-08-2008, 09:15 PM
2000GTP's Avatar
Some people will run the engine for a little while with the o2 sensors removed in order to avoid damaging them during the "break-in" procedure.
2000GTP is offline
Old 09-08-2008, 10:35 PM
karpetcm's Avatar
2000GTP, i want to run nitrous as well, did you have Madz28 tune it for N/A and just pull timing with the mallory 685 ? also wanted to ask how long meaning inches should my o2 extensions be they have 12,24 and 36.
karpetcm is offline
Old 09-09-2008, 06:44 AM
2000GTP's Avatar
The 12 inch extensions should be adequate. And yes, the tune is for N/A purposes, the Mallory box provides the means to pull timing and also the window switch.
2000GTP is offline
Old 09-09-2008, 10:08 AM
Shon Herron's Avatar
HerronPerformance all the way!!
Shon Herron is offline
Quick Reply: Wheres the Cheapest Place to buy LT Pacesetters?
