While motor is out, what all to do...
I am going to pull my motor/tranny out in about a month to do a heads/cam/BIG stall convertor in my car.
so what are some other things to do while the motor si out?
I am starting to think about a oil pan, oil pump, all new seals, etc...
how much can you do a BUDGET 355 for? I mean, I am almost going to be replacing just about everything under the hood.
Re: While motor is out, what all to do...
all i know is it takes way more than you think at first to do it right.
i have more in my stroker than i paid for the car, and im not done yet.
a motor that will make the power you want will require new suspension, brakes, tranny(a4), rearend, all of which will need to be replaced or drastically upgraded. and none are cheap.
good luck if you decide to do it, but dont get stuck where i am driving your mom's beat up stang cause your almostr a year into the build and buying parts paycheck to paycheck.
carguyshu
01-22-2017 11:19 AM
10-31-2016 11:09 AM
alex5366
03-27-2015 03:30 PM
NewsBot
12-28-2014 06:20 PM
