White smoke above 5k
I just aquired A new car with the Le1.5 pack and bolt ons, i recently noticed a white poof of smoke at hard accel above 5k, this car has no cats and runs great with no leaks, could this be because it has no tune/cats?
Re: White smoke above 5k
If I remember correctly, "white" smoke is "normal" (or is it burning coolant?)....blue smoke is oil burning...black smoke is running rich. I used the quotations on the white since you shouldn't normally see any color smoke on a well tuned engine. On cold engines with cats (but your's are cat-free) people claim to see a white smoke, but that is actually water vapor since the cat converts the hydrocarbons into H2O right?
Are you sure it's not blueish tinged?
not sure if u got it fixed yet or not but i had the same problem with mine just before the motor went it was the head gaskets leaking due to the pressure at those rpm's. hope thats not your problem. check the plugs for spotting or water disoloration.
it stopped doing this for a while and now its back, its a healthy puff and only up high, and when i did my header gasket i smelt something sweet under there when i fired her up, please any suggestions before something bad happens!
jackpawt883
09-10-2015 08:53 PM
