White smoke at start-up
Old 05-15-2003, 04:51 PM
  #16
Mizz96Z28's Avatar
Take your radiator cap off when the car is cold then start it. If it keeps bleeding off air bubbles then the compression of the cylinder is more pressure than the coolant system so thats why you don't see it with the engine running but when you turn it off the compression in the cylinder is no longer there and the pressure of the cooling system is able to pump the coolant into the cylinder while it sits. Ask me how I know Also after you turn off the engine listen to it. See if its making any weird and unusual noises. Mine was making kinda of gurgling noise but it was very subtle until I was under the car looking at stuff then I could hear it.
Mizz96Z28 is offline
Old 05-15-2003, 05:35 PM
  #17
LeeS's Avatar
Bad96firechicken!
If your car is running rich and you have catalyst converters it will smell like sulfur. It will also produce white steamy smoke! All cars will steam a little at startup no matter if weather is cold or hot. Mine does it!
As long as you don't loose coolant your okay as far as your engine having a head gasket leak.
I really think all the problem you are having is just a rich running condition Fixit!
LeeS is offline
IndyZman
10-22-2015 02:17 PM
Hal Fisher
09-30-2015 09:03 PM
frankrizz
09-23-2015 04:21 PM
jackpawt883
09-10-2015 08:53 PM
Quick Reply: White smoke at start-up
