who has the best price on heads
Re: who has the best price on heads
What have you done to the bottomend?
Advanced Induction carries bare casting Trickflows you can have them worked before they are even sent too you rather than buying them elsewhere shipping them too you then to a porter and getting harware you wont use or paying another middleman.
If you are still just using a 355 though I would say send out the stock heads unless you did the bottomend specifically with the BIG chamber on the Trickflows in mind then you are pretty well stuck using them or something else with a big chamber.
the bottom end is built, fully forged, -21.1 cc dish pistons, the car is a turbo car, and I need more flow, and as for that, the larger chambers are a plus, just looking to upgrade from ported stock castings. I am not looking for ported heads, I have that under control, just the cheapest place to buy them. I just don't have enough to go with some afr's yet, just a step up for now. thanks.
oldschool
02-09-2016 09:21 PM
NewsBot
12-28-2014 06:20 PM
