Who here has pulled out an LT1 harness?
I'm got everything in the engine compartment loose, I'm just wondering what's behind the dash the needs to be disconnected...the ALDL connector? Trying to get a scope of what remains, I'm swapping everything into another car. Thanks in advance.
Re: Who here has pulled out an LT1 harness?
Behind the dash should only take you a minute to disconnect. It's only 2 or 3 easy connectors. The grommet will come off the firewall, and the whole thing pulls out.
It's the black circle/uncovered wires:
http://paradox.shacknet.nu/dave88lx/.../blueloom8.jpg
Here is a complete picture of a harness. Note the 4 connectors past the firewall grommet that have to be disconnected.
C220 and C230 are here. One connector (a/c evaporator) is plugged in on the HVAC housing and the other (C210) is tucked under the RH dash.
Uses and pinout of those connnectors are here.
Darth Xed
13
07-22-2002 12:45 PM
