Who here is putting 400 RWHP/RWTQ Down on Stock Heads and NA?
#18
I'm not reall impressed with anyone's porting. There are a couple guys that can do solid work time after time, but these guys putting down 400rwhp aren't trapping over 116-117mph w/ reasonable raceweights. Something doesn't add up, IMO.
A local guy dynoed ~399 and trapped 119 - GTP heads/cam/396ci (~3600). The good Tx weather helps, but the gap is so big its hard for me to believe. Cars are weird .
Ryan
Ryan
#19
396 = more power under the curve
#20
Originally posted by Fastbird93
Grease, you got a dyno graph??? I'd like to see the TQ curve.
96-speed - With full race weight and stock wheels, I've gone as high as 117.72mph in the 1/4. Next week I'll have 15x4 and 15x10 racing wheels on, about 60lbs lighter and with the cold weather we have now I hope to trap higher than that
#21
Originally posted by Grease
HERE is my dyno sheet, and as you can see, they don't get much flatter than that.
#22
Originally posted by SkarodoM
There aren't too many over 400rwhp, even if you count inflated STD #'s...
Originally posted by Realquick
Those are STD #'s and not SAE?
Grease, do you have the data sheet with the pressure ect so people can convert that to SAE if they want?
I got duped by the stupid mustang shop i got my car dyno'd at. I specifically asked if the numbers were corrected, but not to what, my bad. They gave me 'fluffed' STD numbers.
-brent
#23
Found them, SAE numbers. 404.8rwhp, 365.1rwtq.
That is still more than what I've seen from cars with GTP stage II heads and a 306 cam. And my heads are just "Econoport" heads that I screwed up and Phil brought back to life. They really should be used as door steps or paper weights. they flow 254/188 @ .500 lift
#25
Did you have to undercut the valves at all with that cam, or was it "plug and play" so to say? I'd like to think I could just throw some new springs and the cam in the car.
#26
I was a little over 400rwhp STD. The SAE #s are in the sign. AI ported LT4 heads for me
Contrary to what a lot of people think, there are only a few stock bottom end LT1/4 cars pulling over 400rwhp SAE on a dynojet. 400rwtq isn't gonna happen w/ only 350 cubes.
#27
graph 1
Graph 2
My dyno graphs...with major ignition problems which will soon be fixed. Should expect to see 425-430 SAE, 450-ish STD. Did I mention that my dyno was on pump gas, stock intake, stock stroke and NO CUTOUTS?
Expect to see times in the LOW 11's and traps 120+. Since it do go 12.3 at nearly 110 with bolt ons in crappy weather....
Graph 2
