Who makes 65cc or larger lt1 head
I'm looking for a set of heads that have a larger then 65cc combustion chamber.
Who makes them. 75cc would be perfect.
thanks in advance
thanks in advance
Static compression is only a build figure and has no impact on overall engine performance. Depending on what type of cam you plan on running you may not need such a big CC'd head to get the desired dynamic compression ratio.
Can you provide a little more info on your build? I'm assuming you're going to be going FI?
I spoke with them about that. They have not made a LT1 head larger then 65cc since 2005. It says 65-75cc on there site but that is not correct.
F'n1996Z28SS
08-23-2023 11:19 PM
oldschool
02-09-2016 09:21 PM
