Who makes thicker head Gasket!
#16
Re: Who makes thicker head Gasket!
Originally Posted by kmook
As far as I know (which may be incorrect)
GM stocker @ .049
Fel-pro 1074 @ .039
GM Impy @ .029
Mr Gasket 5716 @ .026
GM stocker @ .049
Fel-pro 1074 @ .039
GM Impy @ .029
Thats why I asked for someone to correct me Man, I sure thought the factory LT1 gasket was .051. Wonder where I got that? Hmmm
Oh well.. I tried
Dave C.
#18
The1074 is not a round bore gasket....it is slightly "D" shaped.
Not sure of the other ones.
I would closely compare the volume of the gasket, not the thickness, if you are trying to correct compression.
#19
No, I'm not trying to correct for compression, just figure it out as close as possible with the exsisting non-cometic gaskets. If the bore of the gasket is 4.125, and the bore of the cylinder is 4.030 then there is a bit of area left (shrouded by cyl head and block as it may be), is still area to be considered for figuring out static compression.
10-31-2016 11:09 AM
