Who sells and balances dragon slayer cranks.
Hi all,
Recently I’ve spun a main bearing (due to low oil pressure probably) that has killed the block. The dragon slayer crank as measured by the machine shop needs 0.02 under mains and 0.01 under rod bearings. I’ve located another standard 4-main block which I’m gona use for the rebuild.
I don’t feel comfortable machining the crank where I live so I’ll bite the bullet and get a new crank. I need a good place that stocks and balances Callies dragon slayer cranks.
Re: Who sells and balances dragon slayer cranks.
I didn't thought that Callies custom balances thier cranks to individual requirmet. I just want to call a place tell them I have 5.85" eagle h-beam and the specific srp piston and they know what to do.
I'll try them out tonight definetly. Maybe Combination or Flatlander racing as other options.
Rich
