Why do my legs heat up when i drive? tranny overheating?
well simply asked already when i drive around i find my legs start to get warm if not hot, ive started using the floor fans... is this due to a overheating tranny?
this bad opti is forcing me to always be downshifting
If you are running air conditioning, floor vents are cut off at max cool which is the only setting that doesn't let in outside air. GM's excuse for this is that not letting in outside air would make the humidity go too low in the car. That may well be true in Detroit but not in Texas. I modified my AC to be optional inside/outside air in any vent setting so now I have cooler feet in the summer. This has an additional advantge of not being poisoned by stinky exhaust in traffic when running the heater in the winter.
01-23-2015 01:13 PM
