Why do people stress about premium!!!
#16
Originally posted by Cmr0z28
Most speedways around here dont even HAVE premium...just 87 and 91.
#17
OldschoolSS, I don't know where you got that stuff but its BS. Its a high compression engine that requires high octane gas.
#21
"Most companies that sell calibrations eitherthrough a chip or by actually reflashing the lattercomputers, lean, not richen the mixture. Anotherfactor is the factory ships the vehicles with an 87octane spark curve, so a small power increase ofapproximately 5 horsepower can be gained byimplementing more spark advance and using pre-mium fuel."
This is about the LT1 in our cars taken from gms. As you can see the car is programed to run on 87.
#22
The quote below does not sound like the car's program is based on 87 octane, though it will run on it (just maybe not well).
from the owner's manual
Fuel
5.7L LT1 (Code P)
The 8th digit of your vehicle identification number
(VIN) shows the code letter for your engine. You will
find the VIN at the top left of your instrument panel.
(See “Vehicle Identification Number” in the Index.)
Use premium unleaded gasoline rated at 91 octane or
higher. You may use middle grade or regular unleaded
gasolines, but your vehicle may not accelerate as well.
The gasoline you use should meet specifications ASTM
D4814 in the United States and CGSB 3.5-92 in
Canada. These fuels should have the proper additives, so
you should not have to add anything to the fuel.
In the United States and Canada, it’s easy to be sure you
get the right kind of gasoline (unleaded). You’ll see
UNLEADED right on the pump. And only unleaded
nozzles will fit into your vehicle’s filler neck.
Be sure the posted octane for premium is at least 91 (at
least 89 for middle grade and 87 for regular). If the
octane is less than 87, you may get a heavy knocking
noise when you drive. If it’s bad enough, it can damage
your engine.
If you’re using fuel rated at 91 octane or higher and you
still hear heavy knocking, your engine needs service.
But don’t worry if you hear a little pinging noise when
you’re accelerating or driving up a hill. That’s normal
and you don’t have to buy a higher octane fuel to get rid
of pinging. It’s the heavy, constant knock that means
you have a problem.
Fuel
5.7L LT1 (Code P)
your engine.
you have a problem.
#23
#24
the difference between a full tank of 93 and 87 here is LESS THAN $3.
$3!!!!!!!!!!!!!!!!!!
wtf is wrong with you cheap scum if you cant scrape together a measly $3 for your engine.
i cant stress enough how pathetic you are for not filling up with the premium.
if you cant afford $3, you should go buy yourself a honda or other econo-bucket.
#25
I see the point of running 91 or 93 in our cars and i agree with the facts. But i think you can get the point across without calling someone ...
Act your age , not your shoe size
cheap scum
i cant stress enough how pathetic you are for not filling up with the premium."
#26
Now for the mature readers there are so many factors in deciding what octane to use. And for me 87 will theoretically and in real world work great on a mostly stock car running in the midwest. Temperature and humidity also play a role in octane requirements so does ignition timing. I being an engineer for one of the major producers of internal combustion engines in the world I would know a little more than your average car guy about the subject. Try pumping some of that 110 octane fuel into your car and see how good it runs I'll bet you it will run like crap because you don't have optimal conditions for ignition of the fuel. More octane is not always better.
#27
i think all they are trying to say to u is that the LT1 sense's knock on below 91 ctane fuel...thus the PCM pulls timing and it runs like a v6..If the owners manual says 91 oct. or higher...they said it for a reason..if u wanna drive around all day with lost power and bad timing be my guest...but there will always be LT1's out there like mine that run premium and are getting the true potential out of their LT1...
#28
Another thing to consider here guys, is the guys rooting for 93 or nothing, are modded to some extent. I know I dont like running anything less than 93, simply because I dont have the equiptment to monitor for KR, and I dont want to risk any damage.
91 or above guys!! Like they said, saving a few bucks is just taking the life off your motor, if the octane is low your car WILL ping. Maybe not enough to notice, but enough to potentially damage something.
#29
I work at shell and always fill my car with shell premium 93 since the day i bought it nothing else has ever went in it....except i think on a road trip i put in ultra 94 cause there was no shell stations around.
#30
I put premium in my eclipse and it's almost stock right now... Even on an economy car, the computer can learn and adjust. If you use premium gas the car will run stronger plain and simple. If you don't use premium, don't hot rod the car or you will most likely detonate - once again, plain and simple. Also, I don't care how many road tests you have done, GM designed the lt1 engine to run on premium so that is the most logical choice - once again, it's plain and simple.
Oh so what was the point of this thread again? To make fun of those who don't use premium haha.
