why is my car so slow?
#32
ill be home again this weekend as always. I have a code reader too to help. We'll get er back to normal
#39
But you have alot of suspension mods, so DRs will be your friend
I'd say get those O2s changed and if you have any exhaust leaks you need to get those fixed too. Also check for vacume leaks, those can be a real killer for power. Hope you get your problems figured out
#40
Im currently working on getting a Y-pipe to take care of those exhaust leaks, new o2's, seafoaming, changing plugs and changing to synthetic, cleaning MAF and throttle body, and then Ill see where Im at
Drag radials on the way as well!
#41
Either that or there is something wrong with your tune? I don't know for sure, but it seems that your car should be a little faster than what your getting out of it.
#42
If it gets to the point where the tune is in question we should try to meet up and I can throw my tune in there to see if that works any better for you, don't worry I have all the software needed to do that...
#44
I now see your point. good luck I hope you find what your looking for.Keep us posted on what you find. Thanks ,ayers1967
#45
so far i put seafoam in my gas tank and I gotta say I noticed a difference VERY quickly.. so thumbs up to that..Still have to:
Seafoam the rest
Clean MAF
Clean TB
Change Plugs
Change Oil
Change o2s
then well see whats up
Seafoam the rest
Clean MAF
Clean TB
Change Plugs
Change Oil
Change o2s
