why are my dyno numbers so low???
Old 05-11-2003, 09:40 PM
  #16
CANTONRACER's Avatar
Well, thinner gaskets actually do help. You make more compression, which is a good thing.
Did you degree your cam in?
You lucky you made that power being that you still have the stock exhaust manifolds.
CANTONRACER is offline
Old 05-11-2003, 09:46 PM
  #17
RCF925's Avatar
I just pulled a tired bone stock LT1 out of my 94Z (M6) with 160,000 miles on it and it dynoed 270 RWHP . All that was on the car was some SHI$% aftermarket muffler.
RCF925 is offline
Old 05-11-2003, 09:54 PM
  #18
I help out at a local dyno shop and we don't get even close to these numbers...now we got a "tired" LT1 with 160K miles being bone stock that makes 270 rwhp...who you kidding here? Is this the let's make LT1's bullshOt rwhp day?
But OHIO is the land of the slowest cars and the lowest hp cars....yeah, were on a mountain....not...110 deg average days....not...tracks suck...not...drivers suck...not...
Old 05-11-2003, 10:42 PM
  #19
My95Z's Avatar
I didn't want to get a fight going.... everybody jsut calm dow..
I guess I just need headers
My95Z is offline
Old 05-12-2003, 01:01 AM
  #20
GeneralZ's Avatar
Throw in a set of headers and you'll have it made. Grease on this board used to have the same cam with long tubes, and made around 330 HP. BTW...hopefully this thread doesn't get locked because some people can't controll their anger
GeneralZ is offline
Old 05-12-2003, 06:37 AM
  #21
ucrazymonkey's Avatar
Thats what I tried to say. I host Dyno Days here in San Antonio. I have probably seen at least 40 different cars dyno about 120 pulls. I have never seen the numbers some have indicated with there bone stock LT1's.
ucrazymonkey is offline
Old 05-12-2003, 08:49 AM
  #22
2MCHPSI's Avatar
I don't think you're too far off considering the mods you have. You will pick up quite a few ponies with a set of headers and a decent cat-back system.
BINGO!! Headers and cat back will really wake the car up..
225 RWHP stock?? LOL
LT1's vary a lot for some reason on dyno's stock (tolerances from the factory)_Some people just get luckier than others... You sure as hell cannot take GM's h.p. ratings, and try adding drivetrain loss to get RWHP.
245-250RWHP on a M-6 is normal.
2MCHPSI is offline
Old 05-12-2003, 09:11 AM
  #23
gb95zconv's Avatar
Yep!.....headers and catback and see at least 30 more rwhp.
gb95zconv is offline
Old 05-12-2003, 03:47 PM
  #24
hairbear21's Avatar
As far as the head gaskets go, a thinner head gasket will effectively RAISE the compression ratio. It will NOT be much, but it will raise it a little, and higher compression=more horsepower. It may have only gone from 10.5:1 to 10.6:1, but hey every little bit counts.
hairbear21 is offline
Old 05-12-2003, 03:56 PM
  #25
LT1derful's Avatar
I'm thinking the numbers look about right to me. I wanted to dyno my car the other day at our state shootout, but just couldn't spare the cash.
I'm thinkin 290rwhp.
But for me, horsepower, I could give a rat's ***...I want timeslips. But, that's just me I guess.
And, as far as high mileage making more HP...I do believe that. I've got 160K on mine and it runs like a CHAMP!! Seems every pass I take on the track I'm picking up close to a mph...and I'm not doing anything different to the car!
LT1derful is offline
Old 05-12-2003, 04:57 PM
  #26
Umbrae's Avatar
I watched a 94 Trans Am convertible A4 with ONLY a moroso cold air intake make 250hp at the wheels a couple weeks ago. There was also an M6 95 Z28 with a K&N filtercharger and a flowmaster muffler make 278hp. Both of these cars went back to back to make sure the results were accurate. However in my case, I only put down 283hp with a ram air box, edelbrock headers and flowmaster cat back. Then again, my HP NEVER PEAKED as I had a burnt wire, but my torque did, at 330ft/lbs
-Cam
Umbrae is offline
Old 05-12-2003, 05:36 PM
  #27
97Whitez28's Avatar
My buddies Z which is a M6 with just CAI, and Corsa made 280RWHP and 312LB/FT, not to bad for what it had....Another had a T/A made 260 and 300 or so I think with his A4....He was basically stock, if you call a Cutout a Mod.....
Why can't you launch a CC306 Car with stock gears?....I haven't been to the track yet, but I can tell you my 60' times aren't going to be affected negatively.. I am running the stock 3.42's and they launch just fine...
97Whitez28 is offline
Old 05-12-2003, 10:21 PM
  #28
My95Z's Avatar
i decided when I get the monehy I will get the hooker super copm headers and the hooker catback and I will le toyu know how it goes
My95Z is offline
Steve69SS396
Track Kill Stories
15
08-10-2015 02:45 PM
racecarz28
03-30-2015 09:55 PM
Roadie
02-16-2015 10:34 AM
YellowT/A
08-07-2002 12:30 PM
Joe Brodman
07-24-2002 05:24 AM
Quick Reply: why are my dyno numbers so low???
