will 1.6 SA rockers hold up on 570 lift?
I would like to know if SA 1.6 rockers will be reliable and hold up to 570 lift cam or should I go to the expense of NSA rockers set up. Which is better- crane gold's or comp rockers? Thanks...
Re: will 1.6 SA rockers hold up on 570 lift?
Is it 570 with 1.6's? I have a CC306 that is 575e with 1.6's and they work fine. I believe the Crane golds are better but I'm sure it's all a matter of opinion. Personally I like my GM 1.6s
I used GMMP 1.6 SA rockers with my old GM847 (0.595" lift)...they held up just fine. The only thing I would recommend would be to spend some extra cash and go with ARP rocker studs. I used the stock 3/8" studs originally and snapped one within a few weeks. The ARP 3/8" studs I used to replace the stock studs have been holding up for over 2 1/2 years now with no problems.
Speeds8erM-1
07-18-2002 11:36 PM
