Will 95 lt1 fit in 96 camaro??????
Old 09-13-2008 | 08:51 PM
matt14's Avatar
Question Will 95 lt1 fit in 96 camaro??????
I have a 1996 camro z28 with a lt1 and a 6 speed manual transmission.
im thinking about buying a 1995 lt1 longblock out of a 95 z28.
i was wondering if it will fit in my 96 z28?????
Old 09-13-2008 | 09:49 PM
rcguy_77's Avatar
yes it will work
Old 09-13-2008 | 10:27 PM
Counted Out's Avatar
Is something wrong with your motor now?
Old 09-13-2008 | 10:47 PM
matt14's Avatar
we think it has a blown head gasket
but it has 205,000 miles on it.
and the 95 has 8,000 miles.
Old 09-13-2008 | 11:18 PM
It will work as long as you transfer the things the 96 uses to the new engine.
Old 09-14-2008 | 11:58 AM
matt14's Avatar
wat all would i need to transfer???
Old 09-14-2008 | 12:10 PM
Physically, they are identical engines. The differences:
-crank position sensor (96 only), with different timing cover (96 has hole for crank sensor) and crank hub length (96 is shorter to allow for CKP reluctor)
-knock sensor resistance (96 is 100Kohms, 95 is 4.5Kohms)
-vacuum switch for EVAP purge detection (96 only)
-drivers side exhaust manifold (96 has large triangular flange for the cat to connect to)
Old 11-30-2008 | 11:05 PM
merim123's Avatar
I just noticed this about my setup too. Taking the timing cover off and my rebuilt engine has a keyed crank whereas the 96 did not have a keyed crank. anyone know if i can get my 96 crank hub keyed?
Old 12-01-2008 | 05:28 AM
All the factory LT1 cranks have a keyway. No year had a keyed hub from the factory. I think Thunder Racing sells a keyed hub. Look under the supporting vendor index.
NewsBot
12-24-2014 11:05 PM
NewsBot
12-21-2014 06:55 PM
cmdeshon
Parts Wanted
12-16-2014 07:58 AM
TheGreenZ28
Exhaust System
12-06-2014 10:23 PM
12-04-2014 11:56 AM
Quick Reply: Will 95 lt1 fit in 96 camaro??????
