will this harmonic balancer work?
Re: will this harmonic balancer work?
The 90030 says it's for INT. balanced engines which if yours is stock, it is externally balanced. Everyone says both should be neutral but in reality, many stock ones are not. Since they went to the trouble of putting just int. balanced on the chart, there must be some difference. Check with the MFR before you bid on it.
well, my engine is being built, so they needed a harm balancer to put on it for balancing, so i guess that wouldnt have mattered, but i found a stock brand new one for 80 bux, so i gott that one
cyteone
02-07-2015 06:04 PM
smokin5s
07-24-2003 10:47 PM
1LEThumper
07-14-2003 12:45 PM
