Will I need new Injectors?
Old 03-07-2008, 02:37 PM
  #16
Counted Out's Avatar
Originally Posted by mdenz3
O.P. I would highly recomend new injectors for you with the 503 cam. FYI, stock GTP injectors flow about 33.5lbs at stock LT1 fuel pressure and can be had for about $5 each on GTP forums.
And to think I was about to spend $200 on a new set. Thank you.
Counted Out is offline
Old 03-07-2008, 05:31 PM
  #17
Is there a particular year GP I should be looking for?
Old 03-08-2008, 07:40 AM
  #18
GREGG 97Z's Avatar
I'm looking to replace my stock injectors as well, this sounds like a really cost effective idea. Does anyone have more info on this? Are many people out there using GTP injectors?
GREGG 97Z is offline
Old 03-08-2008, 07:43 AM
  #19
2000GTP's Avatar
I would imagine only the supercharged series had the bigger injectors, the N/A models would not need the extra fuel delivery. Also, the supercharged 3.8 Series II engine was in more then just the Grand Prix, it was also in the Regal,Riviera,and Bonneville platforms as well.
2000GTP is offline
Old 03-08-2008, 04:44 PM
  #20
marshall93z's Avatar
Where from? That's cheap as hell!
marshall93z is offline
Old 03-08-2008, 05:10 PM
  #21
Whoooooppsss. Typo. $300*
Old 03-10-2008, 12:36 PM
  #22
Gotcha!
Old 03-10-2008, 12:47 PM
  #23
Yeah, but you will have to find at least 2 GTP engines to get enough injectors.
shoebox is offline
Old 03-10-2008, 06:26 PM
  #24
lol
Old 03-11-2008, 08:50 AM
  #25
kgkern01's Avatar
So can anyone confirm the GTP injectors flow rate as that? I will jump on those if that's the case.
kgkern01 is offline
Old 03-12-2008, 09:02 AM
  #26
Fish89's Avatar
I am curious about injectors as well. I am still running the stock ones and I am curious if larger injectors would be needed or worth while.
I have an LT1 in my 89 Camaro. I am running the hotcam, 1.6 RR, headers, catless exhaust, LT4 KM, 160 thermostat, and a basic tune (not dynotuned).
Fish89 is offline
Old 03-12-2008, 10:51 AM
  #27
2000GTP's Avatar
For those mods, the stock injectors should be up to the task.
2000GTP is offline
Old 07-17-2008, 08:11 PM
  #28
MarcR94v6's Avatar
Anyone look further into GTP injectors? I found a place that has some from $50-$150 of varying years....of course, you'd have to buy extra, as already stated.
$200 is still a bargain from what I've seen.
MarcR94v6 is offline
Old 07-18-2008, 01:52 PM
  #29
He meant $300.
Old 07-18-2008, 04:22 PM
  #30
slomarao's Avatar
If your going to buy a injector buy something from Racetronix, they are it for fuel upgrade products.
They make a 32lb and a 37lb. Both will handle your needs.
slomarao is offline
Quick Reply: Will I need new Injectors?
