will loudmouth from 01 fit 93 ?
Re: will loudmouth from 01 fit 93 ?
Yes it will fit, but you will need to extend the pipe to meet up with your y-pipe(even if you had a cat, you would still need to extend it some) and you may need the newer style hangers (not sure). And yes, it will be louder without a cat. They are louder on LT1s vs LS1s in general
You will probably need some hangar work done, and you will need an S-pipe. They can be bought from SLP or your exhaust shop should be able to make you one. The loudmouth will be pretty nasty sounding with out a cat. Nasty as in crappy. In my opinion.
04-03-2015 10:54 AM
racecarz28
03-30-2015 09:55 PM
