Will my rear hold with 3:73 and 2800 stall?
I am going to order my stuff this weekend do you all think i will have a problem with the rear holding up?
I will be getting the3:73 gear package from Thunder
BFG Drag Radials 16"
and i am looking for a used stall around 2800-3000
and an ajustable Tq Arm
I also have LCA's, SLP Panhard bar, LT headers. Undrive pullies, CAI
Should i go with lower gear?
Is your car an auto or M6. A auto will last longer but if your cars a stick its like a timebomb. It will happen its just a matter of when.
Just no 6000 rpm dumps and you should be fine for a while.
Later,
-John
Later,
-John
autos are easier on the rearend than manuals. you might break it you might not, its a crap shoot.
i plan to test my rear out this season.
2800 stall/3.73/et streets
with decent traction and 1.6.-1.7 sixty foot. i hope to touch 11's.
i will let you know how it holds up.
jesse
jesse
Drag Radials spin just enough to avoid an explosion....been running on mine for 9 years and only 1 rebuild from the limited slip failing...no breakage...3.42s might be better, however, you'll have a hell of a time controlling traction with 3.73s and BFG DRs...the 4L60E has a 3.06 first gear, remember...
-Alan
-Alan
I have 3.73's and the 2800 Vig Stall. However I am on street tires and don't know what traction is . I am looking into a set of etstreets or drag radials. My mods are listed in the Sigs + BMR LCA's. I think I will be alright with my mods launching off idle or maybe a 1500rpm launch.
Originally posted by LPE Z convt
Mine has held up just fine with a 2800 stall and 3.73 gears its been like 2years... That is with 17inch nittos on back....
jesse
I dont think i will ever go to the track (a least for a few years)
How ever i am VERY "abusive" on the road and i drive every day,
The only Qrt. Mile passes will be at the local street races maybe like 10 runs a night twice a month.
Originally posted by QCKZ28
do you see the track often? what are your sixty foot?
jesse
jesse
jesse
jesse
Hey Jesse what have you dynoed your car at? What suspension mods have you done ? BTW nice track times.
LPE cont, that is me, i havent tested rear out at all.
the best sixty foot i have pulled is 2.06 on unheated DR and easy launch. hopefully this season i can pull some 1.6-1.7 on my et streets....
IMO it wont last until next fall.......
jesse
jesse
F'n1996Z28SS
08-23-2023 11:19 PM
