Will these fit LT1 heads ???
Will valve springs off of a 2002 LS1 car fit an LT1 head ? I was
just doing some comparing between comp cams beehives 26918-16
springs and stock LS1 springs , and I noticed they are pretty much the same
exact spring . So will the LS1 springs work on an LT1 head with a cam
around .600 lift ? If so will the 787-16 retainers fit the LS1 springs ?
I searched for a while and found nothing on this so maybe its a new
find
Comp Cams beehives 26918-16
http://cgi.ebay.com/COMP-CAMS-CHEVY-...QQcmdZViewItem
Stock LS1 springs
http://cgi.ebay.com/LS1-beehive-type...QQcmdZViewItem
find
Stock LS1 springs
Re: Will these fit LT1 heads ???
Originally Posted by 11secgen
yes but you need a special retainer.comp makes em. lemme know if you cant find the part number.
Is the part number for the retainers 787-16 ???
And any idea on the max lift stock LS1 springs can handle ??
Originally Posted by AZ2ENVY
So will stock LS1 springs handle up to .600 lift on an LT1 head ? Thanks
Originally Posted by Severous01
they'd better...my friend's camaro is a 355 blower motor with about that much lift and lsx springs. he's going to be pissed if it doesnt.....
Are they stock LS1 springs ? Are they on an LT1 ?
Stock GM LS1 valvesprings are NOT good for .600" lift the comp 26918's are. The LS6 aren't even good for .600". Don't cheap out on one of the most important parts.
Im not cheaping out on anything . I was just curious if they would work
or not cuz they seemed similar in some aspects
oldschool
02-09-2016 09:21 PM
TheGreenZ28
Exhaust System
12-06-2014 10:23 PM
