Wires for LT1 with long tubes
Guys I need a set of wires for LT1, I am tired of the AC Delco because the are so short and passes too close to the headers, I would like a set that I don't have to cut(like the accel) I am looking for ones that come like the AC delco but longer, wich ones should I get and where..
thanks
thanks
I had both MSD 8.5mm superconductors and Taylor 8mm. For OTVC applications, I find MSDs are easier to make but requires drilling out the Made For You looms. The Taylors are a little more difficult to make but will fit Made For You looms. Both MSDs and Taylors are good wires.
Originally posted by GhostZ
My buddy used to run MSD 8.5's in the stock location.
Why don't you just get OVC's? What's the problem with cutting wires?
Get msd pn# MSD-32129 those are the LT1 wires that you cut yourself. Thank god no more burned #5 & #6 wires
Originally posted by InjectedSS
Yea but now I run the MSD cut to fit wire's bish and you know this
Get msd pn# MSD-32149 those are the LT1 wires that you cut yourself. Thank god no more burned #5 & #6 wires
Get on Messenger bish.
Just order the custom fit Taylor Spiral-Pro wires from Summit Racing. They're longer than stock, costs only $42.98, and they work great! I wrap heat reflective tape around certain areas of the wires for added burn protection from my longtubes.
I used MSD 32129, Universal wire set, Chevy LT1 w/straigh opti boot.
I think it also depends on what kind of LTs you have. I think OVC wires work better with the Hookers and Jet hots but with my FLPs I think its better to use wires that go in the stock location.
BTW I am using Taylors right now.
Originally posted by luis nunez
Sorry, I have hookers lts non coated
This may ne stupid but what is OVC?
