Wires for LT1 with long tubes
#16
Carlos.. Do u have a link or part number from Summit for the Taylor spiral pros u got? I just want to make sure i get the right ones. Also do they have OVC looms that come with it? The summit ones are for Long tubes right (hooker)
Thanks man..
Thanks man..
Originally posted by carlos64030
CamaroBoy96Z28...there was no need for you to make your own wires. There are plenty of companies out there that have custom fit, longer than stock wires for our cars.
#19
Originally posted by InjectedSS
yea those are the one's that are already cut and ready to go.. Those are great if you still have the STOCK manifold's.. The MSD-32149 are the one's that you cut yourself and have all the required boot's for the LT1...
MSD-32149 = Universal that you must cut to length yourself
MSD-32129 = Custom fit that go in the stock location
Don't want to confuse anyone going off these numbers when buying wires
Bryan
#21
Originally posted by ShelbyZ28
I think you have them switched...
Bryan
Bryan
#22
Well.. No $hit I just said that
EDIT: I guess I messed up to in my original post. Just to straighten every thing out
MSD-32149 are custom fit
MSD-32129 are universal that must be cut
#23
Thanks man..
Thanks man..
Sorry it took so long for me to get back to you. The part number for the Taylor wires that I have is: TAY-74239. These wires are longer than stock, but they aren't long enough for OVC. I personally don't like the OVC look, I like to try to keep my engine bay as clutter free as possible. My wires are behind the headers, but not on the factory plug wire brackets. As I stated before, if you use heat reflective tape on certain portions of the plug wires that may come into contact with the headers, you won't have any problems running them in the stock location. You guys may also want to keep in mind that you should always try to keep the plug wires as short as possible.
#24
yeah, i got the MSD-32129 = universal from Summit
also got this 3' section of foil-coated tubing, 1.25" dia, CoolIt or ThermoTec, can't remember, its some kind of cloth-like material covered in silver foil. the wire are routed through it coming up from the opti and behind the alt
then i had some of this corrugated silver reflecto tubing that was stiffer and you have to slice it down the middle and squeeze it back to cover it. with the Taylor 1200F firesleeves and that, i got nothing touching my OVC wires now, and they are well protected near the jet hot shorties.
01-05-2015 07:14 PM
07-04-2005 05:00 PM
