Wiring issue for 93 to 94 engine harness
Hey guys
I am working on a 93 to 94 engine harness conversion
The car is a 93 z28 m6
It's a 96 motor out of a t/a with 93 intake manifold,93 ecu and harness
Is there any difference between 93 and 94 harnesses
Re: Wiring issue for 93 to 94 engine harness
To answer your direct question, 93 and 94 harnesses are completely different and do not interchange. Now, if you want to use a 93 ECM and harness on a 96 engine, you can do that if you want. It just depends on what of the 96 you want to be able to use.
I am going to use the 96 motor,93 intake,and 94 (ecu,harness). Do you have anything detailed about this. I'm a little in the dark on this situation
http://shbox.com/1/harness_connector_faces.htm
A fellow member bought this from a friend with it done already
I just want to put a 94 harness on a 93 z28 any difference
It has a 96 block and heads only
Alex Barnes
01-24-2015 10:21 PM
01-05-2015 07:14 PM
