Worn GMPP guideplates
Hi,
I noticed recently that my valvetrain become pretty loud, so I decided to see whats goining on. Under valve cover I saw that almost all guideplates are worn and some of rocker arms are not centered over valve stem, although there is no worn sign on pushrods. Here are pictures (sorry for quality - it's from mobile)
Do I have just bad luck, and should I change these guideplates with other GMPP or should I look for any other possibilities of this situation?
Re: Worn GMPP guideplates
Originally Posted by Kurt Crosbie
Same thing happened to dhirocz. GMPP guideplates must just suck. Is it only happening on the driver's side?
What lifter's ya got? Ya got a small base circle cam? Ya getting enough lube to the Top?How much oil pressure? Your push rods the right length? Rocker shaft's installed with the flat side up? Valve covers hitting rocker's causing a side load?
- Comp R,
- it's LE2 cam (by Joe O.), lift 0.569
- yes (800 rpm with slow flow from pusrod - didn't check higher rpm's)
- ok
- stock length 7.2" - didn't check but stock lt1 heads with stock GM gasket - so should be fine, i think ..
- I suppose so, although whole job was completed by mechanic
-I don't think so - valve covers were modified
guideplates has around 4k miles.
Originally Posted by stereomandan
Were the GM guideplates installed with the "05" stamped in the guideplate facing up?
Dan
Dan
