Worth it to do LE heads with no cam?
#16
Re: Worth it to do LE heads with no cam?
Originally Posted by ShawnMacAnanny
Yes lloyd can port any heads unles they were screwed up IE the guy punched through a water jacket. He even ports aftermarket heads. His LE heads flow 270/190, Lt4 heads flow 250/170 right?
The ones I bought flow 258/182 @ .500 and 260/191 @ .600
#17
ok me and buddy put a cam in to sdifferent engines no problem at all. then we do heads without pulling the cam and he spins a bearing.
call mti and ask them advice on chengine a heads and cam packeage. they will tell you to pull one head putt the the new one one and then do the other to hold the block in place.
maybe we have been reading different threads about spining bearings.
but good luck.
but good luck.
10-31-2016 11:09 AM
